Mopar_mark - HEMI CUDA Part II
Jon Connolly
Post by Jon Connolly »
Tis a thing of beauty :thumbright:
Can`t believe how light this is coming out :thumbright:
A few more jobs ticked off the list today ;)
Off to the states in about 10 days time, so will collect dry sump- fuel pump drive, plus fuel pump drive cable...
Maybe ready in early/mid May
Can't wait 8-)
awesome sexy black batmobile, for the track ;)
it just needs an awesome black batmobile Bentley supersport sat next to it for fast street, ;)
Mopar Porn-tastic!!!!! 8-) 8-) 8-)
Rogue Trooper
Post by Rogue Trooper »
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
Note to one self, remember to take detailed photos before stripping a multi stage oil pump down ;)
Finally, pump all now back together & modified to accept fuel pump drive....
Would of been much simpler to order a pump with the drive in the 1st place, oh for hindsight :roll:
Doncha love a bit of hindsight :roll:
jerry
Post by jerry »
Progress has been slow in the last few weeks...What with trips to US, family life, & the infamous oil pump bracket saga, finally made some progress...
Oil Pump Brkt #1 went in the bin, Oil pump Brkt # II never made it on the car & finally Oil Pump Brkt #III was a success, so finally can move onto the next jobs.
This has been one of the most tedious & trying jobs on the car that I can remember...
Wicked :thumbright:
jerry
Post by jerry »
Last pump bracket went in the bin :D
Had to have a rethink, as lack of adjustment was being caused through by being on the same centreline. Also, could not get a belt in the size I needed. So new bracket fabricated with different pivot points. What a a saga ....
All good now, with pump & belt fitted, along with a new tensioner. New oil lines made & plus a couple of fittings to crimp & will be finished Mon/Tues...
Few small jobs to tick off the list, plus family life, but should be at Dragstalgias
Jerry II
jerry
Post by jerry »
Double post...
Jerry II
jerry
Post by jerry »
Almost ready for Dragstalgia's.... few small jobs to finish off tomorrow
Not sure if this link works ?
Jerry II
ITS ALIVE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So SO SO happy for you fella :thumbright: :thumbright: :thumbright:
brilliant
jerry
Post by jerry »
I never seem to be able to stop :D
Had a water leak issue at the Dragstalgias... Only on the upper holes near the inlet side.
Although the gasket should of accommodated there was a big miss alignment between the holes in the block to the holes in the head.
So out with the scriber, Drills, Taps & plugs
OFFENDING HOLE
SQUAREish to ROUND HOLE
DRILLED, TAPPED & PLUGGED
PLUGs DEVCONED & NEW HEAD WATER HOLES
NEW HEAD HOLES ALIGN WITH BLOCK & GASKET
Jerry II
