68 Charger. Engine swap. THE END.
It's a Federal pump but your brackets are for a Saginaw pump.
http://www.440source.com/powersteering.htm
- Dave-R
Found it.
So this is the bracket to fit that pump you have to a 440.
But like I said it has been modified. I welded on two thick washer/spacers to move the bracket forward or something. Can't remember now but it was for a good reason at the time.
If you can use this let me know and you can have it for enough to cover postage.
Thanks Adam. Did wonder about that... Its back on how it came off, but 180 deg might do it.
PS - Dropped oil out as matter of course (getting closer to fire up). It was like new - golden and clear. Had it even been run on that ?? Was most impressed.
PPS - What the heck do you tighten oil filters with ??? Mein gott ! Almost had to punch a bar through it to get the damn thing off. 30 mins with a chain wrench ! All good now though
- latil
Oil filters can be fun sometimes,the rubber seal seams to weld itself on. Don't really tighten oil filters,just screw on handtight + 3/4 turn tighter and check for leaks on startup. Always put some clean oil on the rubber sealing ring first and if possible fill the new filter with oil before fitting.
2 forward, one back...
Guess what ? Throttle mount brackets are different on a small block. Also aftermarket ones sit too high to be used with standard throttle cable. Now need to source a BB bracket... therefore sum total of tonights work is "put in one fuel pipe". Still - it all adds up I suppose.
I should be writing this down. "The 1,000 differences between a small block and a big block"
(madness causes grinning)
Progress coming on though. Will post pics as soon as I can get onto the other computer (wife is on it)
Edit - couple of pics. Coming on... Think I'm missing Nats though.
