no one want to guess what the bump steer did then
(this is one wheel remember so figures would need doubling for total toe-in)
so in totally standard form, taking ride height at zero, two inches of bump caused 50 thou (1.1mm) of toe out to three inches of droop at 120 thou (3mm) of toe in (170 thou tracking change over 5 inches). if you take just one inch each way at ride height, which is where the suspension will spend most of its time, it went from 35 thou toe out to 40 thou toe in. (that's 75 thou of tracking change over two inches)
maximum recommended is ten thou per inch of movement
and with the 1.5 inch shorter track rod measured one inch either side of ride height. 5 thou toe out to zero at ride height to 5 thou toe out! thats right, it has virtually eliminated bump steer
not what I expected either. (that's 5 thou of tracking change over two inches)
even at two inches either side of ride height it only moved 18 thou. only at full droop on the last inch it moved to 60 thou toe out.
so the Jag rack will work and work very well
