I have tyre problems to add to the fun- I took the wheels for balancing and the machine couldn't cope with the size
One wouldn't give a reading and the other wanted 360 grams, which is about a 3"x 6" patch of weights. That's gonna look great!!
The tyres have all sorts of lumps and bumps on them, is that normal for these stupidly big MT's?
Tyre fitters opinion was that they could not be balanced
Well Paul, way I see it is there's tyre fitters, and then there's tyre fitters....all the M/T's I ever saw on cars were nice and smooth as they should be, maybe you got a duff set?, are they new?
We had a problem once at the Pod with a 14 slick and had to take it to 4 different tyre places in town till one of them got it done ok, the machines may look the same but maybe aren't, or its who's using them.
They've not done 100 miles since I bought them Les, but that was about 8 years ago!
I bought them and the wheels in the US, had them sent to a mate in NY state, he had them fitted for me then shipped them over here along with my axle etc.
Thanks for the info, I'll try elsewhere for balancing, he did seem a little out of his depth
I've just spoken to Dave Billydoo and we strongly suspect my very expensive axle kit came with cheap-n-nasty bearings
I guess I'll be investing in some rather dear Green bearings then...
Yes, Dave B mentioned that Pete...
tbh I'm more concerned about the buying than the doing, they'll be the most expensive bearings I've ever bought
Latest word on my wonky tyres- They can distort if the car is left sat on them for as little as 8 months without moving. That's probably happened at least a couple of times in the 5 years since I fitted the axle etc.
I had to chuck away a perfectly "good" set of Eagle slicks recently - loads of "tread" wear left on them; but in reality they did not work (all the natural resin had gone) and the sidewalls were cracking.
Duncan had the same on the AMX.
Put in the bin, sob quietly; and batter Paypal. Sorted.
Wheelie Bars are all installed, as is the Fibre glass front end, and the front end suspension is now set up to give maximum weight transfer and roll rotation!!!!
