The 340
I think they just raided the parts bin as they were on zero budget compared to the Bow-tie brigade.....underdogs, don't you love 'em :thumbright: :thumbright:
DaveB
Post by DaveB »
True about the header bolts going into water Pete,thats poo.
BB chevys head bolts/studs go into water :?
V8 Sam
Post by V8 Sam »
And there was me expecting a 3 paragraph answer...
:D
DaveB
Post by DaveB »
Small blocks are cool too Sam :thumbright:
V8 Sam
Post by V8 Sam »
DaveB wrote:Small blocks are cool too Sam :thumbright:
trust me!
i already know that! :D
Yep, but Big Blocks are cooler ;) :D :D
And an inherently better design ;) ;)
the dodge
Post by the dodge »
arnt big blocks a bored and stroked small block turned 180deg?
:lol:
the dodge wrote:arnt big blocks a bored and stroked small block turned 180deg?
I don't get the 180 degree bit, but in essence the BB has the same configuration as the SB, but with the Gayness removed ;)
the dodge
Post by the dodge »
the big block distributor is at the other end? :)
the dodge wrote:the big block distributor is at the other end? :)
You mean the RIGHT end ? ;) ;)
The end you can actually reach it and see what is going on with it. :thumbright:
Yes a real head ache saver , and changing the water pump is easy , so is intake no water to deal with , you can change out the oil pump with out having to dump the oil, the 440 great engine :thumbright:
Les Szabo
Post by Les Szabo »
Fair points made.....but if you look at it like this:-
my stock CR 340 with just a .590 cam single plane and 850DP = 371hp
my stock CR 440 with .650 solid cam, single plane and same 850DP = 398hp
figures worked out weight/ ET/mph...+/- a few hp either way.
that tells you something I guess about the 340!
Les
Yes.
It tells me the 440 produces Bananarama! loads more torque... ;)
