As Tim cracks on finishing the welding I've had some unfortunate news about the Charger's engine. I'd not had time to start it since buying her back in the summer. All I had to go on was the fact it ran and the compression test was ok. Sadly we've found it runs and didn't sound like it was knocking (only ran a v short time) but there's zero oil pressure. I mean none. Removed oil pump and checked it - fine. Span it over without oil filter on and there's a surge of oil. It's odd. Either there's a big blockage somewhere or much worse. I'm now in a situation where we will have to crane out the original 383 and pull it apart.
Unless there is something else to try I can't see any other option. At least while it's out Tim can repair the tiny bit of rot on one front chassis leg, plus we'll know how good the engine internals are. It's a bit sad, especially as the mileage is low.
Hey ho.
