NGK XR5
NGK XR5
Hi,
Is there anywhere in the UK that sells the V-Power XR5 plugs by NGK ?
My googling isn't what it used to be !
ATB
G'day mate!
I have located XR5ix (iridium) here;
www.sparkplugs.co.uk , they are £7.79 each + vat.
Then whilst trawling around I came across this which is worth a look;
http://www.dodgecharger.com/forum/index ... ic=28130.0
If you still want XR5 plugs I'd bring some in from Mancini;
http://chucker54.stores.yahoo.net/ngkplugs.html
Gareth
Post by Gareth »
Bonzer reply Kev :lol:
Cheapo plugs here we come !
Bearing in mind the Bananarama! fuel around these days , #6 heat range (ngk) plugs should be used on all stock motors , you'll find the motor will run a tad cooler also.
& for you chappies running Champions :roll: , if the porcelaine stays in one piece then #9s will do.
Gareth
Post by Gareth »
Duly noted, ta :)
