Belts somthing not right ???
On the engine there is a crank pulley with 4 groves for fan belts
starting from engine towards the front bumper
1st grove is empty
2nd grove is a belt to alternator and the alternator keeps it tight.
3nd grove is power steering pump and uses the pump adjustment to keep it tight.
4th grove is to water pump/fan and no adjustment the belt is slipping and cant tighten.
what am i missing ???
JohnR
Post by JohnR »
Should go round crank, alternator and then water pump , pas belt OK and they probably used one other for A/C comp good job you have not got a serpent belt !!!!
John Rutledge
but then my water pump does not line up with my alternator.
do i need a diffrent pulley onto the water pump with a big dish off set ??
or diffrent alternator brackets ???
JohnR
Post by JohnR »
OK so does the PAS, crank and water pump line up ? if so go with that but the alt,water and crank should line up unless someone has buggered with it
John Rutledge
JohnR wrote:OK so does the PAS, crank and water pump line up ? if so go with that but the alt,water and crank should line up unless someone has buggered with it
Water pump only lines up with the 4th grove on the crank hub and nothing else.
The pully on the water pump has no off set
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ngine2.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... gine-1.jpg" border="0" alt="Photobucket"></a>
i think i need another water pump pulley like this one ????
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 18_164.jpg" border="0" alt="Photobucket"></a>
JohnR
Post by JohnR »
Looks like it , as I think they have just mixed up different parts to get it going did it have A/C and they have taken it off ??????? or W/P may have failed and thay slung something on there ?????
John Rutledge
it was a non ac car and no parts ect.
So looks like i need this pully
Found oil leaks to be sump gaskets on engine and G box and rocker cover gaskets have striped all sumps off in the rain in the street yesterday and will get some parts on monday
( still love it and full of enthusiasm)
Thanks Jon :thumbright:
autofetish wrote: ( still love it and full of enthusiasm)
Hey AutoF,
You should get some photos and a proper intro of the car on Members cars!! :thumbright:
AllKiller
Post by AllKiller »
Hey Wil your cars not an A/c car but the 400 may have been from a A/c car. ??
Alternator belt should normally be triangulated fitment ( via crank, water pump, alt) to keep tension.
one of those grooves should match up
just so you know there are a lot of different pulley set ups...Dunc might have a something :thumbright:
ALL KILLER NO FILLER
Hey AutoF,
Yes i will i have been so busy covered in oil trying to get the sumps off with a couple of old spanners from my grandad in the street have not had time. I will get the camera out tomorrow.
autof -
Couple of pics from my engine installation - As stated above, belts for water, alt etc should run triangulation, and power steering off another.
The pulley on mine is only 2-groove.
I went through similar, and got all my pulleys from '440source' for very reasonable price. All shiny and new, bolted on first time. (Get the right belts too ! US ones have different profile, Euro ones will slip/wear !)
Cant see your pics clearly - photobucket doesnt link ?
Thanks
Looks like the water pump is off a motor home or something as the bottom hose is way to big for the rad.
You engine is very clean wish mine was that nice
ps. thanks for the head up on us euro belts i dint know that
