60 minutes
pete walton
60 minutes
Post by pete walton »
Found this old video of the old Silverline team......car in from run,remove all saftey kit,remove plugs ,remove all fuel ,remove oil ,drop oil pan,remove clutch can ,remove clutch pack,remove every rod bear and replace check old bearings ,replce clean oil pan,remove oil filter and replace,check all valve springs and rockers check lash perform leak down test .rebuild clutch ,pack chutes,have a cup of tea,put fresh oil in put fuel in ,replace valve covers ,put in plugs start it up,,,replace belly pan ,replace saftey kit ,replace side panels,,,,ready to go again ,,,,60 minutes if no damage...takes me back :thumbright:
Les Szabo
Post by Les Szabo »
Easy running a slammer eh Pete......
Les
