No two engine compartments are going to be the same, sometimse a generic filter relocation kit won’t work without ugly brackets. This versatile and compact, multi-position Remote oil filter base might just be the answer, it is CNC machined from 6061-T6 Aircraft aluminum, and can be rotated through 192 degrees (threads helicoiled for strength). Designed to take any performance filter with a ¾ unf fitting. The pipe fittings are 3/4unf to take standard pipe fittings (-8AN to -12AN).
£85.00 +p&p
oil filter relocation
- oil filter 001.JPG (57.93 KiB) Viewed 844 times
- oil filter 004.JPG (54.25 KiB) Viewed 844 times
- oil filter 002.JPG (60.59 KiB) Viewed 844 times
too much is never enough
