Front sitting too high?
Hi chaps, I reckon my front end is sitting way too high. I fitted mahoosive rear tyres look to see if a 15" rear 14" front would give the desired look, but thefront remains obstinately high.
Sooo, lower front via torsion bars?
Also, reckon rear springs are pretty saggy and wonder if expensive mono springs would provide a better solution.
Opinions welcome :thumbright:
bi wel side.jpg (45.1 KiB) Viewed 518 times
more big whl.jpg (40.55 KiB) Viewed 518 times
big whl rear.jpg (30.13 KiB) Viewed 518 times
rear side
mope side rear.jpg (36.27 KiB) Viewed 514 times
John
Post by John »
Stick a big block in it Miles ;)
On a serious note, try lowering it by the bolts on the K frame first as it may have the desired affect asthetically to the rear
Now passed customs.
Now on route.
Now in posession.
Now costing me sh*t loads.
Big block :twisted: ..not replacing new built 340 just yet!
Whats this about lowering K frame bolts John? Never heard of that one before. What craziness is this :o ?
Carl
Post by Carl »
Mine is down as low as it will go on Torsion bars and looks like this with 15's and 235/60/15 on the front
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
turn the torsion bars down 3 turns run the car around to get it to settle re do trackng the back looks perfect to me just fit top quality shockers
John
Post by John »
Sorry miles, I meant the torsion bars
Now passed customs.
Now on route.
Now in posession.
Dart Vader
Post by Dart Vader »
What Duncan said was what I was going to say, honest
Btw 245's available again
J
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Thanks boys, I will do as suggested.
Justin, give me a moment to regroup as I'm wondering which way to go with the wheel/tyre combo :thumbright:
charger01
Post by charger01 »
Carl wrote:Mine is down as low as it will go on Torsion bars and looks like this with 15's and 235/60/15 on the front
Drop the front with the torsion bars , jack the car up first :thumbright:
mad machs
Post by mad machs »
Well, after fitting the tyres for Miles.... all I can add is....
Air Shox, the choice of champions ;) :lol:
Mike that is called Mike.
69 Dodge A108
73 Mach1 Mustang
Maybe on a fjord, but not on a Mope............
Mike I believe i donated my air shox to your Mustang many years ago.
I reckon I need 1970s jack up shackles, that'd sort the beggar ;)
I have probably got a set somewhere, when I removed them in favour of Superstocks springs and Hangers - the only way to fly.... ;)
front looks way too high
adjust it as per the service manual like this …
http://www.forbbodiesonly.com/moparforu ... ide-height
setting the correct ‘difference’ between the adjustment blade and the steering knuckle is the way to go as it doesn’t matter what wheels/tyres you’re running
I would do it this way then go up or down from there, whatever is your poison
