Cracked block bores
74challenger318
Cracked block bores
Post by 74challenger318 »
Just a bit of advice here but could a block be linered if all the bores are damaged with cracks, looks like it has been stood with water in the bores and frozen and cracked the bores?
thanks Paul.
Turnip
Post by Turnip »
I think they can but it may not be cost effective depending on what block you have
DaveBishop
Post by DaveBishop »
It will cost you more than the block is worth unless its a super rare
2 x 1969 Dodge Darts
74challenger318
yes super rare :(
block crack.JPG (145.8 KiB) Viewed 424 times
block crack 2.JPG (133.68 KiB) Viewed 424 times
Yes you can but it will be expensive, I reckon it will be in the region of £200 per bore, It will also weaken the block, so it's not something you would want to race with. That looks like something pretty old (early hemi?) so I'd guess the the cylinder bores will be thick which is good. I'd think about getting it crack tested before you spend any money on it, might be cracked some where else that is terminal.
I have to say that the block looks particularly bergarred, but if it really IS that sought after and valuable then Performance Unlimited at York can sonic test a block....
74challenger318
well stripped it and had a good luck and i think its scrap as gone through all water jackets front to rear :shock:
don`t have much luck with engine blocks :( and guy i bought from in the states has gone awol,
thanks for replies anyway,
Paul.
Sorry to hear that Paul.
What is it you are after?
74challenger318
Hi Pete
S26-A or S26 stamped 341/345 hemi
thanks Paul.
