One of them is to upgrade the single circuit system to dual circuit. I have a dual circuit MC and associated bits (thanks Will) but just have a couple of questions as I am planning to renew all the brake lines while I am at it. Im saturated with the web now so need a bit of clarity from you fellas please...
1. What is the exact diameter of the tube I need (I used 3/16 on my Polara)
2. I have used copper in the past and works fine. Is it worth going to steel?? SORTED
3. Will a normal double flare vice mounted tool work ok on steel ? SORTED
4. I have a couple of options when swapping, one of which involves blocking the rear brake 'in' port on the union block by the MC and running a new rear pipe up to the front chamber of the MC (effectively using the block to deal with the front pipes only). What is the best way to block a port? Ive seen a small piece of pipe flared, put into a fitting and then the open end is squashed flat, folded over and soldered. Is that ok or are blanking plugs available? I have the option to put a later block in which utilises all the ports so really just exploring and researching all available options before I get stuck in.
5. Lastly, if I renew all the pipes, what is the best way to bleed the whole system? It will be empty so will I need a suction type bleeder for my compressor or is there another way?? I will be putting new flexis on as well so the system will be dry.
Thanks in advance
Cheers Steve
