Crankshaft hand turning
Does anyone know the socket size for the crankshaft nut on front of 340 engine?
I need to turn the engine by hand to check a few things.
I know it is bigger than 1"
Cheers Ali
challenger
Post by challenger »
ali, if its the same as big block i,m pretty sure you can get away with 30-32mm socket as long as its hexagon
keep it mopar !
32mm does the job as Jim said! must be hex. I've used one many times.
Cheers guys I'll try that.
mike jones
Post by mike jones »
28 mm for a 440 Source damper bolt 6 point socket
All sorted now thanks got an 1-1/4 socket and turned the engine.
