chrysler voyager problem
TrevD
Post by TrevD »
any chrysler mechanics on here.
mine has got hard to start and wont rev over 2500rpm, is this a limp home mode of some sort?
too much is never enough
terryr
Post by terryr »
is the management light on,you may have to get the codes read
Adrian Worman
Post by Adrian Worman »
You may not even need a code reader to extract the fault code Trev.
Put the ign key in, rapidly cycle in this order, but don't turn to cranking;
Ign off/on, off/on, off/on
The digital odometer should come up with 'po _ _ _ _' look up the 4 digit code on Google and start fixin the Bananarama! :thumbright:
Jesus built my hot rod
72 Challenger
65 Barracuda
TrevD
Post by TrevD »
no codes, took it on a long run and it seems ok now, could it be turbo on its way out ??
JinxJay
Post by JinxJay »
petrol or diesel?
TrevD
Post by TrevD »
its a 2.8 diesel
Rebel
Post by Rebel »
Had similar on an Isuzu Trooper, turned out to be a knackered primer pump. Also had air in the pipes because of the primer pump problem, cracked open the injector pipes one by one and cranked the engine until there was diesel flowing, problem sorted.
I think the primer pump is between the radiator and engine block, although it could be on the firewall
HTH
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
JinxJay
Post by JinxJay »
TrevD wrote:its a 2.8 diesel
Depending how new it is, it could be a dpf problem. If you mainly drive round towns and not motorways it can block and and go into limp mode. If this is the case good diagnostic gear can force a regen to sort it out.
Really you need it on good diagnostic system to read all the data to see if something is out of the ordinary.
TrevD
Post by TrevD »
cheers guys will run it in and get diagnostics done, does seem like a run helps so could be dpf.
