1969 charger steering
n04hs
Post by n04hs »
Hi just see if anyone has put on a rack and pinion to their charger?
Was it worth doing, do you have to change anything fabricating wise?
Thanks.
A world of pain and money. I think there are a few threads running on this.
n04hs
Post by n04hs »
Thanks Pete!
if you swap to a hemi 6 or a slant 6 you can dent the sump
weld some horns onto you K and mount up a GM variable rate Rack
shenanigans with rack end to balljoint mismatch
problems with coupling to steering shaft.
better off with new Borgeson box
or manual 20:1
n04hs
Post by n04hs »
Thanks dave!
Roger
Post by Roger »
n04hs wrote:Thanks dave!
Or nail the box as tight as you can, take the play out of all the worn ball joints, and then add castor, lots of castor. Did i say castor................
