invertor wattage
invertor wattage
i want to run a 700w (3 amp) angle grinder of the car battery with a power inverter. Do i need a 700w or higher/lower rated inverter? I know nothing about electricery. Thanks
Glen63
Post by Glen63 »
You will need a much bigger one, it is the startup surge with electric motors that takes out inverters, a 700 watt inverter would be fine for powering a laptop or something electronic, not motors that have spikes of load on start.
We have a 1200 watt continuous, that handles 2400 watt surge for start up on our houseboat. It works fine for my Bosch power drill, but hated the cheap Tescos vacuum cleaner and would always trip out on startup. Works a full size domestic fridge fine now, but I had to move it nearer the batteries and up rate cables and batteries.
You also need to bear in mind that you need a lot of 12 volt amps to run for any length of time. We now have a pair of 6 volt Trojan batteries in series to get back to 12 volt and they have a very serious capacity of Amp/Hours
http://www.trojanbattery.com/product/t-105-re/[/url]
Adrian G
1968 Charger 318ci V8
1977 Dodge RV Camper 440ci V8
1978 Jaguar XJS 5.3 V12
1984 Mercedes 280 SL
1998 Jeep Cherokee 4.0
1999 BMW 530i
Thanks Adrian, i think i'll scrap that idea and bring the panels home and do it in the back garden, although the missus is not going to like it. I sense a row coming on. :thumbright:
Glen63
Post by Glen63 »
Or you could think about a small petrol generator ? a lot on ebay, but not to small, as same thing applies about startup surges, but you do have to worry about batteries. or the wife !!
Adrian G
1999 BMW 530i
Trigger_Andy
Post by Trigger_Andy »
Just got an old ole going myself.
5.5hp Chinese copy of a Honda Engine. Ran my Chop Saw and Leaf blower no bother.
Glen63 wrote:Or you could think about a small petrol generator ? a lot on ebay, but not to small, as same thing applies about startup surges, but you do have to worry about batteries. or the wife !!
