brake nuts grrrrrrrrr
Dart Vader
Post by Dart Vader »
is it me but are brake nuts welded in place at the factory.
be jesus I know they're not but talk about on strong
couldn't get mine off the block today so had to cut two away, stuck the block in a vice and still couldn't undo the burstewards
It's not like I'm re using the block but Christ on a bike......
grrrrr
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Its "Character Building" ;)
what brake nuts?
the tube nuts on the pipes n that
yes
nasty
two sets of mole grips and a scant regard for safety is occasionally necessary
go a smidge tighter first.
and its always the one where the chances of you snapping the pipe and having too little to cut and flare again
Dart Vader
Yep tube nuts, tight little buggers
still I've practised making new ends up and got a nice finish so now it's time to put it all back together......
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
I just bite the bullet, cut the pipe, use a 6 point socket, get the buggers off and start again.....
Yep me too.
Pete wrote:I just bite the bullet, cut the pipe, use a 6 point socket, get the buggers off and start again.....
Yup. This. I had a couple that were so far gone (tried heat, wd40 etc) I did just this. Cut the pipe, hammer on an old socket 'tight'. You rare at this stage 'committed' as my dad used to say !
Cut em, socket. Done.
done the socket thing,then as it's always Sunday afternoon,drilled out the bit of old pipe and reused the nut. :lol: :lol:
latil wrote: ......drilled out the bit of old pipe and reused the nut. :lol: :lol:
Loving your work, Steve!! ;)
