water in footwells
elevensies
water in footwells
Post by elevensies »
got water in both foot wells on the pickup,
having a hard time finding said leak, even with pouring water onto the truck and waiting grrrrr
iv put Vasaline on wiper holes, iv cleaned up A post area.. im lost any ideas helpful please
ta
MMA 117
support our paras
"Utrinque Paratus"
Re: water in footwells
Maybe running down holes inside the "A" Pillars?
Rusted out plenum in the engine bay?
Roof gutters rot out quick. Normally front corners. Worth a look
elevensies
cheers guys, none of the above, yeah pete i thought id take the air filter off just in case hahah
MMA 117
support our paras
"Utrinque Paratus"
Heater matrix ???
I lost a grommit on the bulkhead once in wifes Rav4. It filled up with water - devil to find ! Toyota put a whole new carpet set in it. Worth a look though - they say water doesnt go uphill, but it does !
Or you take the route i took with my old Marlin - drill a hole in the floor. :)
Ha ha....I had a great old Peugeot 406 that always had water in the spare wheel well in the boot. Drilled a small hole as you say...problem solved! :D
1st rule - it’s only silly if it doesn’t work. Water in car ? Drill hole to let water out. :thumbright:
morgan wrote: Thu Nov 05, 20 9:28 pm 1st rule - it’s only silly if it doesn’t work. Water in car ? Drill hole to let water out. :thumbright:
Doesn't apply to boats tho... :-k
