prop fell off help???
Pete, could you feel it vibrating before the UJ failed i.e. since you bought the car? If it wasn't vibrating before the UJ fell apart I wouldn't bother having it balanced. If it was out of balance you'd have known about it. It'll cost £70 to £100 to get it balanced I think. I've replaced several UJs in propshafts over the years and never had to have them re-balanced, just make sure you put them back together in the same position they came off.
Martin Walker
- latil
I've never re balanced a prop after fitting UJs,no need if everything is marked and put back correctly. I've cut and shortened many props over the years,helps if you have a big enough lathe to part-off and to align for welding.
It sounds like have a dig at James week (he deserves it anyway!
) but I've never balanced a prop in my life and shortened several at home too, without any adverse effects.
That's not to say that from an engineering standpoint it's not good practice, I've just found it unnecessary.
I remember on a mates Pop we had a prop vibration and solved it with a judiciously placed Jubilee clip.
Nothing personal, fellow Rootes Group man!
None taken, you are all a bunch of bodgers!
As a general rule I check the balance of anything that goes round in circles especially if I make any changes to it.
who wants the clever calculation for how many revs your prop can take before it falls apart? Note: this doesn't include 2nd and 3rd order calculations for the harmonics or prop sag issues.
It helps when you have friends on the inside
The crank assembly balances (crank, flywheel, clutch housing, damper) I got done as cash in hand and went after hours and did it myself. That cost about £25 - £40 depending on how much we had to change and how long it took. I used Denis Welch for that since I used to work there.
Rod balancing you can do in your shed with an accurate set of scales and something near a surface table.
I lost my main contact for prop balances, so now I have to pay. At Dave Mac's I paid £85 for a prop rebuild and balance. I think the balance was £40.
