prop fell off help???
prop fell off on saturday (that was after the front brake locked on), got it home and it looks like a badly warn uj, the yoke on the diff and the retaining caps are perfect can i get a UJ rebuild kit from any were and how much will i be looking at???
- mopar_mark
Re: prop fell off help???
Pete_bedford wrote:prop fell off on saturday(that was after the front brake locked on), got it home and it looks like a badly warn uj, the yoke on the diff and the retaining caps are perfect can i get a UJ rebuild kit from any were and how much will i be looking at???
I assume you have a Propshaft loop or are considering one as part of your upgradeslol yea its started, but gud excuse for a disc brake conversion, i new it was on the way out thoe as it did clonk a smigin when going off then back on load.would places like usautomotive and dave eady be able to get um
Here you go PetePete_bedford wrote:no i dont have a loop. another stupid question but what does it do??? does it stop the prop hitting the floor?
http://www.moparuk.com/forums/viewtopic ... c&start=45
And yes, it is to stop the prop either coming through the floor n chopping your legs off and or dropping down and diggin in the ground and flippin the car over.
I imagine you have the small type UJ's, I recently got a set from USAutomotive for about £25. Then i use a place in Coventry called Dave Mac to do the prop build and balance. That costs about £85, seems alot but they do an excellent job.
I am just down the road from you at the moment in Woburn. If you like I can take your prop up to Cov to get done?
- Stu
I have heard very good reports on Dave Mac. Came highly recommended to me when ours started looking out of shape, not had it done yet, though.Bratfink wrote:I imagine you have the small type UJ's, I recently got a set from USAutomotive for about £25. Then i use a place in Coventry called Dave Mac to do the prop build and balance. That costs about £85, seems alot but they do an excellent job.
Anyhoo, Dave Mac is 02476 683239.
