318 into 14,s
Trigger_Andy
Post by Trigger_Andy »
pete walton wrote:Just read up on this baby,273 power runs low twelves high elevens.its all down to money and knowledge
Could be a Commando though? They are 235 HP and the D/Stock was 275 HP outta the box.
Mick70RR
Post by Mick70RR »
Well done, now your after that first 13 second run.
madmick wrote:finally done it 14.8 @ 91mph at superstock on sunday :D
Well done Mick , What's yer next goal?
:help: :read2: :working:
14.7 or better. Come on Ad, get with the programme. :lol:
Well done mick. :thumbright:
See,there is hope for 318's :D
Ian Z
Post by Ian Z »
MadM, did you do anything new to drop to 14's ? Or was it just technique. Or is it a secret? ;)
Mick, why not go with a 360? Much lighter than a 383 and tons of performance parts for 'em. 408 stroker version is a temptation!
A big block will see a SB off. It is not only the BHP but importantly the torque. A 383 can be cheap as chips, but piston choice can be hard these days; and if you are going to spend money on a stroker then get a BIG stroker - a 440 to a 500 (or bigger) is the most affordable it has ever been. Speed still costs, though.........plus all the other parts that will need upgrading.....
Jeff
Post by Jeff »
Pete wrote:A big block will see a SB off.
Now there is a quote! Surely if that were the case all BB cars would ALWAYS beat SB cars?
Pal of mine has a SB camaro... drives it to and from the track, and has run consistant 9 sec 1/4's for the last 6 years! Best of 8.8sec! And yes, it is always driven on the street!
DaveBishop
Post by DaveBishop »
Pete I would agree with you if you said a 440 but because of the weight per cubic inch the 360 has over the 383 I would go for a 360 all day long. You can get so many bits for the 360 and its easy and cheep to stroke it to 408 and even bigger
2 x 1969 Dodge Darts
It's not just cubes, in my opinion it is also flow levels on the heads and other factors.
I just know from experience that a BB is easier and potentially cheaper.....
Jeff
Post by Jeff »
I could fit a 383 in mine... A 440 would need the engine compartment to be widened. Or a 360 stroker.....
What about a 400ci? I have found one of those locally that is running real nice!
Jeff wrote: What about a 400ci? I have found one of those locally that is running real nice!
Jammy get! :thumbright:
