Mega block
Brutus wrote:Well , after havin the crank crack tested , ground .010 (mains & rods) , rods ground for clearance (.007) ..................mocked the bottom end up & found #7 & 8 rod Bananarama! the clinder walls (rod caps sit higher) , was thinking of chamfering the rod bolts but was told to clearance the walls instead , all gotta come out again , will check all cylinders for clearance.
One step forward ten back. :help:
:read2: :read2:
Brutus, might be a pain in the arse mate, but I think you are doing things the right way. Always good to check, double check & check again once more for luck.
I also agree with the direction on clearancing the walls & not the rod bolts. Very easy to cause stress riser, when grinding items such as bolts. I know it can be done carefully, graining & then polishing. But on the plus side, if you ever want to change rod bolts, its a direct swap.
As you always say, better to do it right once...
Cheers,
Mark . . .
Yep , do it right the first time , a little Bananarama! off with the CR bein so low so just hacked off @ the mo , will pull it all appart tommorow , good thing #7 & 8 Bananarama! , as probably would'nt of checked due to the previous rods clearing ok. :help:
:shock: :D
jerry
Post by jerry »
Keep at it Ad wish i could offer some useful input but out of my depth here other than to give some encouragement :thumbright: :D
:iagree: Sums up my position perfectly! But it never hurts to offer encouragement, so hope it starts to go straight soon. :thumbright: I like reading these threads, they teach me lots when I can get me head round 'em. :wacko: :working:
Every cloud eh Ad, get the old Dremmel out and it will be done in no time.
Al would have let it grind itself away :D
NaughtyAlan
Post by NaughtyAlan »
Very funny Bob [not]
Knightcharger wrote:Every cloud eh Ad, get the old Dremmel out and it will be done in no time.
Not as easy as it seems Bob , thought i'd have it sorted in no time...............
Layed the crank in , placed a rod cap & bearing on the rod journal with rod bolt , spun crank & cap then started clearancing the bottom of bore where it hits , :idea1: then thought to meself the rod bolt did'nt foul this much with the rod & piston in the bore , so would be takin too much off :? ...........
Gotta be done with the piston & rod in the bore or too much will be taken off , problem bein the block has to be cleaned every time you drop the crank , pistons & rods in................that ole die grinder spits iron dust EVERYWHERE , doin one @ a time is a nightmare.
Good job it's only a baby 4.625 stroke , must be a pig with a 4.75 stroke. :shock: :D
:help: :help: :help: :help: :help:
There's not a great deal to come off , maybe .060 thou , leaving around .050 clearance , block has already been clearanced for the last set of rods , but the K1s have the rod bolts slightly over to one side , plus the fact the cap sits slightly higher , gotts have a steady/firm hand , don't want the carbide bit throwing itself up the cylinder wall. :shock: :shock:
2 down 6 to go.
10" slicks on the rear , no problem me thinks , tis one heavy bitch. :shock:
:D
challenger
Post by challenger »
aint it an ally block mate whats the weight diff ? :thumbright:
keep it mopar !
Tis a CI block.
challenger
by the time you got the motor sorted mate and fitted you gona be like a racing pigeon anyway thats worth a 10th up the strip :D :D :D just messin mate sounds like you getting there keep on it, some good work there :thumbright:
keep it mopar !
challenger wrote:by the time you got the motor sorted mate and fitted you gona be like a racing pigeon anyway thats worth a 10th up the strip :D :D :D just messin mate sounds like you getting there keep on it, some good work there :thumbright:
You wanna see a racin pigeon in season go take a look @ Blue , was up @ his workshop the other day , threw the old steel alt pully away & had a billet one made up (true) :shock: also saw the slim fast book on his bench. :shock: :shock: :shock: :shock:
Ole Blue was havin heart tremors thinkin about the weight of the Pit. :lol:
:D
Knightcharger wrote: Al would have let it grind itself away :D
:lol:
:idea1: always wondered what the two batteries were for.
:dontknow:.............................. :D
