Charger weight for first MOT
Dave, from memory, the rollers run together, so it should be ok, but i'll check with a mechanic mate first. It's all computerised here so if the readings aren't within their tolerances your'e bucked. Thanks for the advice. Get back to those meetings :D
Mick70RR
Re: Charger weight for first MOT
Post by Mick70RR »
Why don't you go and weigh it at a council waste disposal site, it's a free service. My Road Runner weighs 1640 kg so I doubt if your Charger is 200 kg heavier. Tell the MOT guy it's lighter than it really is and your brakes will get through the test easier.
GeneralWee
Post by GeneralWee »
Would do if I could drive it to the council tip, but it is its first MOT, so no reg plates etc!!
Brakes should be OK - have disc conversion!
Say hello from Rosco!!
69 Charger, 59 F100, 64 C-10
Austin J40
Austin Pathfinder
X350,V70T,Lifan,2CV,Ducato,Tractor, Actionman, Cindy doll and a remote control car!!
PaulR
Post by PaulR »
A vehicle weight is not required for the MOT test. If suitable to be tested in the roller brake tester it can pass on a lock allowance.If more than 50% of the brakes being tested lock (so 3 of the main braking system or 2 for the handbrake)the vehicle is deemed to have met the braking efficiency.The tester would select N/A to the vehicle weight when entering the results. If it does not meet the requirements by lock allowance then it can be tested using a decelerometer as can a vehicle which is not suitable to be tested in the roller brake tester.
Which is what Andy Rob was saying at the start of this thread.
I have never had to provide a weight for my car. Not had it MOTed since it all turned computer based though.
At the first MoT the tester will ask for the weight. I was specifically asked to provide the weight when I booked the first test. I'll check with my mate from VOSA when I next see him to see if things have changed,but that's what he confirmed last time I asked.
GeneralWee
My MOT man said he definately needed weight for first MOT, thats why I was asking.
Austin J40
Austin Pathfinder
challenger
Post by challenger »
as latil says :thumbright: we do mot,s daily weight is needed on the first test , but not needed after that cus its already stored on the vosa computer system , also needs the weight to calculate braking efficiency :thumbright:
keep it mopar !
