Coughed up for a Koffle
Brian J
- Cannonball
seems like a good idea, you can never trust used ally rods, B1,heads are notorious for getting porrus i would get them tested as well,Slick wrote:Bobbo, now that you have stripped the motor I take it you will be replacing the rods....................
Tell ole Big Dog to expect a bill in the post.Slick wrote:Bobbo, now that you have stripped the motor I take it you will be replacing the rods....................
The motor was pulled appart by Hauser not long ago , since then it has'nt had much if not any run time , from what i understand the motor has'nt been run much anyhows , so thinking these rods will be ok.
- Cannonball
Brutus wrote:Tell ole Big Dog to expect a bill in the post.Slick wrote:Bobbo, now that you have stripped the motor I take it you will be replacing the rods....................![]()
The motor was pulled appart by Hauser not long ago , since then it has'nt had much if not any run time , from what i understand the motor has'nt been run much anyhows , so thinking these rods will be ok.,
if your talkin the mtr was pulled apart at hausers when, gasser/steve first had it off mopar mark, YOUR WRONG, i was gonna have the mtr because i thought hauser had checked it over BUT NO, GEOFF NEVER EVEN HAD THE VALVE COVERS OFF THE MTR, THE BIG BILL WAS FOR A MUTTS NUTS POWERGLIDE THAT RAY NOW HAS, a crank evac pump, and a jessel belt drive and mounting it all up etc, not an engine check over,
did not want it after finding that out,
Why were'nt you interested just cos Hauser never tore it down , what difference would it of made?
Well , i think Hauser tore this down , does'nt look like this thing has been started , let alone run , those bearings are mint , look like they just came out the box , unless Hauser fitted these parts , vac pump etc , then i can't understand what the labour bill was for.
- Cannonball
was bothered because off the hassles mark used to have with the rocker gear, dont think i ever saw that engine get down the track in anger, had loads off potential, and i was waitin to see it but never did,Brutus wrote:Why were'nt you interested just cos Hauser never tore it down , what difference would it of made?
geoff used to run a 500 B1 when we were in nappies so i reckoned if he had have checked it and give it the ok then i woulda bought it but he never so not interested,
indy mtrs dont seem to be as troublesome, and never had a prob with rockers on a hemi but B1,S notoriuos for it
Would'nt of put me off , would of got to the root of the problem & worked it.Cannonball wrote:was bothered because off the hassles mark used to have with the rocker gear, dont think i ever saw that engine get down the track in anger, had loads off potential, and i was waitin to see it but never did,Brutus wrote:Why were'nt you interested just cos Hauser never tore it down , what difference would it of made?
- Cannonball
sometimes ya can do without the aggro, and i just did not fancy itBrutus wrote:Would'nt of put me off , would of got to the root of the problem & worked it.Cannonball wrote:was bothered because off the hassles mark used to have with the rocker gear, dont think i ever saw that engine get down the track in anger, had loads off potential, and i was waitin to see it but never did,Brutus wrote:Why were'nt you interested just cos Hauser never tore it down , what difference would it of made?
- Cannonball
yep its deffo the area to watch with em, one off the outlaw anglia guys paul hensher runs a b1 he carries spare everythin for the top end cause off damage/torching etc, bitchin things,Brutus wrote:![]()
Thanks for filling us in Dunc.
