Brake warning light on
Adrian Worman
Post by Adrian Worman »
Nice post Daveman, can we have it saved as a sticky?
Jesus built my hot rod
72 Challenger
65 Barracuda
https://www.musclecarresearch.com/mopar ... ee-rebuild
different thingy same switch and pistons
yesturday couldn't get to this due to restrictive work policy
but today i can
That's a good photo.
The "switch" isn't really a switch in that you can't "click" it or anything. It is just a screw and the wire earths the lamp.
often the contact that you attch the wire to can be dismantled and checked to see the rubber/plastic insert isn't craked and goes right down to the end of the screwy in bit
witorque
Post by witorque »
Thanks for the diagrams, but it is a different version to mine. The electrical screw in switch has a spring loaded plunger.
Must get triggered by a profile on the shuttle.
If these use O rings on the shuttle, then they won't be much good after 40 years....
I expect the front and rear lines will leak across each other past the shuttle. So if a wheel cylinder leaks it's fluid, the front line pressure will escape around the shuttle into the leaking rear line....
I will look at this after the nats
ChrisWitor
Stand / stamp on the pedal as hard as you can like you going to give your self a hernia.
witorque wrote: The electrical screw in switch has a spring loaded plunger.
thats like mine
hence the TOCK
i always believed the shuttle in mine has a profile that keeps it wedged one way or the other once activated by a problem
take tension off the spring in the elctrical switch bit and it goes TOCK back to the middle under the pressure of the shuttle springs.
the bulb in mind was bust so i drove for about 6 months with only the front brakes...
best braking upgrade i ever did was to replace the bulb and reset
