Brake Drum Removal
The Ratchet direction of rotation depends upon which side of the car you are working..............
A proper paint tin opener fits the ratchet just right to move it round ;)
Demon James
Post by Demon James »
latil wrote:A proper paint tin opener fits the ratchet just right to move it round ;)
:thumbright: Good tip Steve, like it.
Demon James
Pete wrote:The Ratchet direction of rotation depends upon which side of the car you are working..............
Mine all ratchet UP Pete, ie: the driver sides front and rear have the toothed part toward the front of the car and the passeger side ones front and rear have the toothed part toward the rear. All the drums appear the same just turned 180 degs on axis :dontknow:
Before I open a can of wrigglers on this I will be able to get more pics as I know I need to replace the cable parts of the adjusters on the front drums soon :)
In the mean time, I'm about to start a war and peace novel/thread on my latest dash wiring problem :scratch:
they only made minor changes to the drum brakes
one was a swap from duo servo shoes to normal shoes in about 1964
duo servo had slightly different sized and positioned shoes so as soon as one dragged on the drum it levered the other one out hard and locked up the brakes. not good. locked rears... a case of trying so hard they failed.
used big diameter cylinder as well.
the other was the self adjuster
early the self adjuster ratchet is clipped through a hole in the shoe and works too well or rusts and binds
later it pivots on a stud.
all new brake shoes can take either clip in or stud provided you have a stud and adjuster to use.
the pictures above is the stud version
if you have bits missing just remove the self adjuster
the aussies never bothered with it on the RTs
Thanks gents....that shop manual pic is much better than mine Gary...cheers! It ties in nicely with what is in previous photos. Got more of an Idea of what I am trying to do now
Dart Vader
Post by Dart Vader »
all else fails, cut the Bananarama! off !!
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
What a great idea mr Vader.... Straight to third base! :thumbright:
Dart Vader
Would pop round on Wednesday as I'm in Bromsgrove, would have brought my light sabre, would be very quick and could do you a circumcision at the same time. :thumbright:
Just dont have the time now..
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Dont tease me bigboy!! X
Arran
Post by Arran »
Sounds to me like the drums are rusted to the driveshaft flange. Put the wheel nuts on to protect the studs and tap the face of the drum inbetween the studs (NOT around the outside of the drum as you could knock it out of shape) all of the way round over and over until the drum starts to 'bounce' off the flange. Once it starts moving, you will be able to tell if you need to move the adjusters as the drum will start to bind up and not turn. :thumbright:
Arran
Post by Arran »
Thanks Arran and that does make sense and would explain why I can spin the drum freely but it wont come off. Going to start with the easiest option that you suggest then progress as necessary i think. A mate of mine who has driven my car says the brakes grab on the front as the rears need to be adjusted up. That would again explain why the drums spin....
Thanks again boys :thumbright:
Yes clean up the end of the halfshaft where the drum sits and give it a drop of wd40. The drum is a tightish fit on the halfshaft. As said,a few well aimed clouts between the studs should free things.
Nice one gents, wish I was off work today....itching to get going on it now I have some ideas about what to do!
Cheers Steve :thumbright:
