FFS!!!
- mopar_mark
- Adrian Worman
The ONLY reason I use MSD is that it has a built in Rev limiter.
Also needed the 20 degree on start up facility on the Race car with locked out timing.....less of an issue on the road car.
I am after and old school small Tach that will sit on top of the steering column that will be compatible with an MSD.....Blue???
HEI (Obvious and $20 well spent) or megajolt Lite Jnr (prgrammabale crank trigger wasted spark 2 maps (starting and track or road and track or NOS and NO NOS)
http://www.ebay.co.uk/itm/GM-CBE4-Ignit ... 592wt_2219
and
http://www.autosportlabs.net/MegaJolt_Lite_Jr.
then if they go wrong its dirt cheap or its your own fault due to bad soldering
dunc never looked at a digital one
happy to take a mooch but unless its obvious (i.e burnt bits) its a damn sight harder (Chips and ICs) than a MSD6 AL (all analogue resistors capacitors and normal stuff) to work out whats up.
and
Always make me wonder why people mount the control box under the hood
They are clean, small and tidy....so mount it under or in the glove box away from heat, fuel, water, oil or anything that can harm it ?
electronics mate, theres just no tell tale signs....they work... then they don't.
when you say small tach what make Pete ??
ALL KILLER NO FILLER
I did not want to mount it in the Glove box, but sadly that is starting to look like the most viable option for all the reasons Steve and Ade has mentioned.
I was going to make a mounting bracket and put it on the Radiator Support, but I think that is too vulnerable for ingress of water if it rains.......
