What are you doing this weekend car related?
Laying the Bee up properly for the winter, and making space in the garage to start work on my murdercycles!
Don't normally work on the car at the weekend, I like to get out and about. I will normally order parts or collect bits for the following weeks work so I don't get held up. I will probably cut out a wooden pattern for the tubs this afternoon.
raven68
Post by raven68 »
Fitting the new door shells and front sheet metal back on the 69 Camaro, assembling the front suspension on the Challenger and ordering some replacement AMD panels( front & rear valance & deck filler panel) for it from Summit, sanding down the Challenger bumpers for priming & painting, spraying the wheels gloss black and filling / sanding horrible bits of bodywork and paint.......... will get some pics posted sometime...
Oh, and I've just ordered the Bassett racing wheels for the RR..... :thumbright:
Blue wrote:Don't normally work on the car at the weekend, I like to get out and about. I will normally order parts or collect bits for the following weeks work so I don't get held up. I will probably cut out a wooden pattern for the tubs this afternoon.
I have got some big sheets of cardboard that we used on the 45" RR tubs if you want them, but it would probably cost more in Diesel to pick them up....
pete walton
Post by pete walton »
I am trying to fix my roof that decided that it had seen all it wanted to see over xmas and blew of down the field.....then i will put my fence back up that also took a dislike to the xmas wind....On a positive note i started the car up it sounded sweet and i will do my chores with a smile and a spring in my step
adrianp
Post by adrianp »
Stuck in electroluminescence hell on the '66 to try and figure out why I've got no dash lights :(
adrian.
Carl
Post by Carl »
raven68 wrote:Fitting the new door shells and front sheet metal back on the 69 Camaro, assembling the front suspension on the Challenger and ordering some replacement AMD panels( front & rear valance & deck filler panel) for it from Summit, sanding down the Challenger bumpers for priming & painting, spraying the wheels gloss black and filling / sanding horrible bits of bodywork and paint.......... will get some pics posted sometime...
Hope you ordered the correct wheel nuts too?
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
raven68
Post by raven68 »
Carl wrote: Hope you ordered the correct wheel nuts too?
Yes indeed........ 1" nuts to suit 1/2" x 20 studs.... :thumbright:
Copper fuel line in, plugs gapped and wired up (Jack did that lot, learning about timing and firing order).
Extra treat, T/A boot spoiler holes drilled so it sits in place, just not bolted it down yet.
Parts collecting tomorrow.
Steve Chapman
Post by Steve Chapman »
Moparless at the minute,i know i know, im a scumbag. So this weekend i shall be mostly welding my LDV camper for its test. Laid in puddles in the outside work shop, you know the score. :lol:
BEEN WORKING ON THE RED TOMATO ;)
Hemimad
Post by Hemimad »
I've destroyed an intake manifold :oops:
Hemimad wrote:I've destroyed an intake manifold :oops:
Errrrr how ??
Hemimad
Post by Hemimad »
With a die grinder trying to make clearance for a Holley 750 linkage on a 69 intake. I cannot use a spacer as it has an air grabber, need a 70 intake.
kev73dart
Attending car shows and celebrating my Birthday on me own!
Post by kev73dart »
Hi All
You may think my weekend sounds a little more glamorous but it ain't all its cracked up to be.
Today is my Birthday and I spent it on my own driving 60 miles to a small car show in a place called Boynton Beach, Florida (see my other post)
There was also a Mopar show but it was 3 hours away but I should have gone!
Weather has been perfect today, clear blue skies and about 25 degrees.
Called to Advanced Autoparts on the way back to pick up some Accel leads for my Duster.
Tomorrow I am off to Ft Lauderdale for an all makes show hosted by the Corvette club of America, and possibly a second one a bit further North at Deerfield Beach, Florida.
It keeps me busy and I get to experience the world, but being away from home gets to you sometimes!
But at least I can gather all my parts for the Duster!
Getting really tempted to clear lacquer it as it is for this year, any opinions appreciated!
Cheers
Copy of DSC08527.JPG (244.47 KiB) Viewed 1011 times
Copy of DSC06708.JPG (237.41 KiB) Viewed 1011 times
Copy of DSC06705 (2).JPG (222.79 KiB) Viewed 1011 times
Copy of DSC06704.JPG (235.14 KiB) Viewed 1011 times
You can sleep in your car, you can't race your house!!
