db wrote:My un-stroked 360 puts out over 400hp. Stock bottom end, Indy heads, M1 inlet, Lively cam, 750dp (son to be 850).
Just a thought...
Yes Paul it does and then some, and your right, you don't need to go stroker at all.
If the crank needs a grind, grind it Johnny, its no big deal, should clean up at -10thou??....a set of 10:1 slugs at zero deck to compliment your Ally heads, an XE268 hyd or similar, an airgap intake, prep the bottom end and have it all balanced and your done for a nice torquey street package that should be well in excess of 300hp.....
Les
