Brake line distribution block
Rebel
Post by Rebel »
Mick70RR wrote:
Rebel wrote:Really? did you just run the pipes from the master cylinder straight to the discs / drums, did you split them with a "T" piece to get to each wheel?
From the MC to a line-lock then onto a t-piece then to each front caliper. The proportioning valve was fitted to the chassis under the drivers seat in line with the brake pipe to the axle. I can reach the adjuster while sitting in the drivers seat.
Thanks Mick, :thumbright:
'68 Dodge Charger
‘75 Ford Ranchero
'93 Toyota Hilux Surf
YouTube - Double Zero Garage
ANTON
Post by ANTON »
Here's a picture of the wire. It goes into the harness and to the firewall plugs and then into the car.
www.apdautomotive.co.uk
APD Automotive
22 Willow Lane
MITCHAM
CR4 4NA
0208 6400729
Rebel
Post by Rebel »
Thanks Anton, it's definitely missing on mine. I'll have to have a look under the dash to see if it's been tucked inside at some point or just removed altogether before looking to replace it
'68 Dodge Charger
‘75 Ford Ranchero
