Valiant charger restoration
Re: Valiant charger restoration
Nice work
Tranformation.... Looking great
- Minty
- Location: Terry Step Hindhead,Highest village in surrey
A bit of colour before air intake panel goes back on
- 1F617625-CB69-48B8-9286-A86535252EEF.jpeg (115.72 KiB) Viewed 3208 times
- 1BD1C4C0-DBEB-4D16-A96F-0366533B6615.jpeg (160.22 KiB) Viewed 3208 times
- 74CC6AFD-FBCE-4CC1-B76A-EFAFE3083D79.jpeg (138.44 KiB) Viewed 3208 times
1972 Chrysler Valiant Charger 770 -1006 Magnum 360 Rocket ship
1972 Chrysler Valiant Charger 770 rolling shell under restoration -667
2002 Chrysler Sebring Convertible
- pete walton
nice work ,what primer did you use ??? I am about to embark on a painting journey I might regret myself
- 272290091_7118749371500524_217564199872875186_n.jpg (89.69 KiB) Viewed 3202 times
nice work, are you refitting the scuttle with panel glue so as not to burn that paint? you'd be ok painting the 'inside' of the scuttle panel too that way.
neil.
neil.
- mopar_mark
I always start with an Etch primer for bare metal.
Then a 2k primer, dependant on body I might switch to a primer filler
- Minty
Two coats of Mipa epoxy then three coats of Mipa high build Petepete walton wrote: Sat Jan 22, 22 4:39 pm nice work ,what primer did you use ??? I am about to embark on a painting journey I might regret myself
Great work Terry, keep the pics coming.
- Minty
- Minty
Yes Neil going to use panel adhesive and might get away with the odd spot weld if I can get away with itmygasser wrote: Sat Jan 22, 22 9:40 pm nice work, are you refitting the scuttle with panel glue so as not to burn that paint? you'd be ok painting the 'inside' of the scuttle panel too that way.
neil.
Factory spot welds were leaning more towards the front of the lips
- Minty
Will do Derek
- Minty
have you got access to a spot welder rather than plug welding with a mig/tig? they don't produce any where near as much heat which'll help.Minty wrote: Sun Jan 23, 22 8:30 amYes Neil going to use panel adhesive and might get away with the odd spot weld if I can get away with itmygasser wrote: Sat Jan 22, 22 9:40 pm nice work, are you refitting the scuttle with panel glue so as not to burn that paint? you'd be ok painting the 'inside' of the scuttle panel too that way.
neil.
neil.
- Minty
Unfortunately not
I know you can hire them
Might try a couple of plug welds and see if it generates to much heat
