Well finally took the plunge and tugged the lump out of the Bee and tonight took the Gearbox which smelt like Adams ferrets over to the Herts meet to pass onto Blue to check over.
I suspect it is a TCI replacement item as there is a witness of an oval sticker on the casing and its painted black.
the converter was a 9/12".
Took it in OLd Yella and picked up Big AL and Adam on the way now, the F2 cab is not that wide and whilst I am quite svelte unfortunately the Black Charger boy,s are not and Adam had his flying Jacket on which was like having a sheep between me and Big Al.
Had to open the windows to fit in and Adam had the 4 on the floor between his legs and after a couple of embarrassing gear changing attempts it was decided that Adam would change gear Big Al was calling them and I was clutching and steering.
It was a bit like driving by committee but the old girl got us there and back home.
I have stripped the Bee engine and what I thought was a 500 stroker turned out to be a stock 440.
It has raised deck pistons, solid cam and lifters with gears for timing.
The heads gave been extensively flowed and have large valves.
The sump has an external molidium pump and a swinging pick up under a
splash plate.
The whole thing was topped of with a single plane and 1050 Dominater.
So now I have the dilemma whether to stroke the existing engine and replace the heads or to source another engine.
Decisions decisions
