Will´s 1968 Dodge Charger
Striped all parts down now sand blast and powder coat or zinc plate
Its like looks like a car boot sale here very depressing part of build no car and just rusty parts :cry:
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure653.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure659.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure661.jpg" border="0" alt="Photobucket"></a>
So next up was axle brace
As this is a DIY project i gave it a go.
First im working with the fact the axle was straight as all original bearing where 100% perfect.
First i strapped the axle to a RSJ (under the wooden table top)
Then welded on 2x metal rods to see if its still straight when welded
The axle was then bent 2.5mm down towards table.
Then welded on brace starting at the most outer point then working inwards. Welding over x (like you do a head gasket up)
The welder was a mig and set to 168amp with low wire speed.
After welding the axle was unscrewed from table and came back to with in 1mm.
I cant see that 1mm over the whole length the axle will matter but only time will tell.
Then powder coated.
Have given up with the chrome powder coat as it is starting to fade so gone for a gun metal Grey
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 510642.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... /193-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/196.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/199.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/201.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/204.jpg" border="0" alt="Photobucket"></a>
Also welded on a sump plug i made on a lathe
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/207.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/206.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/208.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/217.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/220.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/226.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/228.jpg" border="0" alt="Photobucket"></a>
sinny
Post by sinny »
Now that I like! :thumbright:
Looks spot on mate.
Shaun 'Moparless' Senior
MMA Club Chairman
Rogue Trooper
Post by Rogue Trooper »
8-) Good job :thumbright:
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
Will, you're going to have to get ya finger out if you want it ready for the Nats, about 9 weeks away now.
Derek wrote:Will, you're going to have to get ya finger out if you want it ready for the Nats, about 9 weeks away now.
:cry: If its on a trailer fresh out the painters will it count ;)
yes
even not so fresh and in bits
just don't park in the swap meet area or it will be lighter when you leave
Jules
Post by Jules »
Dave999 wrote: just don't park in the swap meet area or it will be lighter when you leave
:lol:
MMA/750
Had a problem with my powder coating machine went faulty. The company sent me out a replacement asap now back to powder coating.
This gave me some time to sand blast lots of parts.
Seats bases came out really good.
Decided to paint my brake calipers with a high temp paint.
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure464.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure463.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... e275-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... e276-1.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure466.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure462.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure469.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure473.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure474.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ure475.jpg" border="0" alt="Photobucket"></a>
I hoipe you haven't forgotten how all this lot goes back together Will! :oops:
Ivor wrote:I hoipe you haven't forgotten how all this lot goes back together Will! :oops:
:runaway!:
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sh/cut.jpg" border="0" alt="cut"></a>
Can't wait to see the finished article now mate........... :thumbright:
What you gonna do with all your spare time when its a finished project........
Buy another mopar, rebuild and go 1/4 racing???????? :D
Going to build a copy of an old drag bike called Jade Warrior but with a modern twist Honda vtec turbo ect started to collect parts but dont tell dad :-$
<a href="http://photobucket.com" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... agbike.jpg" border="0" alt="Photobucket"></a>
I bet that feels fast even when it is not moving :shock:
