SSBC
Took the Pit out today , bearing in mind the new pads & shoes need bedding in , it stood on end when i hit the brakes, locking up the rears , it's nice to see the front dip when you hit the brakes.
Got it back to the garage & adjusted the rear proportioning valve , the brakes seem as they should be , so pretty happy with the result , may even lower the rod to the existing lower hole on the peddle , as it seems to travel further due to the higher position of the rod to master , also think i need to fit that residuel valve for the rear shoes.
