Brutus wrote:Gonna be usin a roller in the 572 , street motor too.
Not takin any notice of Firefighter, etc then Adam ??
Ignore at your peril
Firefighter........
A mild street roller/endurance grind will give up some power vs a race stick but it will live much better on the street. You can get away with 200lbs on the seat and 500lbs open on the valvesprings. The more agressive rollers need some pretty stiff spring pressures to keep the valves stable which in turn accerates lifter wear and increases valvespring replacement. Even a mild roller will require some routine maintenance depending on miles accumulated over the course of the driving season.
Challenger 340.............
Apologies for the questions, just trying to "nail" this application.
RACE Rollers that make REAL power, the trade-off is durability on the street, like there is none,
and,
up to and including the point where it's not IF, but WHEN, ya got an Oil Pan full 'O broken trunions.
What are you looking for ?
Challenger 340.................
The "trick", if your gonna do the street driving thing, is to pay very close attention to "thermally stabilizing" the engine & valvetrain prior to any rpm whatsoever !
Just because the temperature gauge reads 180 F, doesn't mean squat !
If you are determined to street it, Do THIS;
Start it, let it bump and fart around at the 1100 rpm, or whatever, NO RPM !,
and wait until the gauge gets up.
Then shut it down and let it sit for 20 minutes for the Springs, etc., can "heat soak" . Usually a good time to quickly pop the covers and do a lash check.
Then, after it's "soaked", re-warm and go toodling, setting off the neighbors car alarms.
ps; you'll know when it breaks a Valve Spring, it'll miraculously pick up power. Then it's Time to go looking seriously at the inners.
You got a V/spring # you are using, I may be able to help with that for longevity.
Firefighter...............
Steve, your assumption is correct....the agressive roller profiles are spring killers. These types of cams are not designed for extended use at low engine speeds. This was what i was alluding to in the previous post. The rocker arms also take a beating with the big spring pressures and the ICH (Dove) rockers won't last long in a street application. Some guys have reported issues with the Comp chrome moly steel (non rollerized fulcrum) rockers with roller cam spring pressures.
The other wear issue is the needle bearings in the roller lifters. Depending on the cam profile you could be looking at new lifters every season or even less.
For these reasons, my preference is towards a milder "endurance" profile that is easy on parts and will live reasonably well at low engine speeds.
OK, I'm gonna speak from the heart here.
Just my opinions, thats it, thats all.
I ain't trying to start any wars, just what 'I think" from my experiences.
Skip the Mechanical Roller, if you're gonna do any street driving at all.
Mopars ain't Chev's, 'nuff said.
Like I said before in another thread, I'm just finishing off a "pump gas" 540 Cheb right now, Merlin 111 & Brodix BB2 heads, and I'm using a "Street Roller" Mechanical Roller Cam profile, that uses springs with a "street friendly" seat pressure of 154# and high 400's # at lift.
From my experience, and others we've done & dyno'd, we'll top 700 h.p.
"It works" !
Now on to my Mopar experiences.
Mechanical Roller Cams, at least the ones that would be similar to the "street friendly" type spoken of above, (that we use in the Cheb's),
just plain don't work sufficiently well enough, in the Mopars we've done, to justify the added expense, parts cycling, and overall eventual grief that we've encountered for "street/strip" engines.
Our opinion, for ANY street driving at all, is that the Flat Tappet .904" dia. Solids available today, can provide equal or better performance in a Mopar, given the precarious Spring Pressures required to really make the Roller "THAT MUCH" Superior.
Comes back to the Spring Rates.
How much better can a Roller Cam be, That uses 150# seat pressure(street frindly) and lower duration @ .050, over a Flat Tappet Solid using 135# seat and big .050 numbers ?
The answer, in my opinion, is "not very much".
Don't get me wrong here, I've used RADICAL RACE Mechanical Rollers on the street, at anywhere between 200#-300# seat pressures, just because I wouldn't use "steriods", and wanted to stay out front.
Those profiles DO make more power, but they just don't "LIVE".
And with Lower "Semi-Race" Mechanical Roller stuff in the 200# seat range, IMHO, it just doesn't make sufficiently more power over many solids, to justify the costs in $ and reliability for the street.
It does make MORE, just not enough MORE, IMO.
In a "nutshell"
I couldn't find that "68364" Crower Spring. It said discontinued. But I suspect from the Cam grind you have, if it was the matched spring, that it's probably around the 200 plus # seat, and a 500# rate ?
If you're intent on a Roller, that Cam setup, imo, just ain't gonna make enough extra power over "half a dozen" Flat Tappet Profiles, to justify the grief I think you'll experience. But the INDY "kit" rockers will survive with it.
If you're intent on a Roller, The only Rollers really worth running, IMHO, are the BIG ones, with the BIG pressures, and they Don't LIVE on the street.
This Comp # 23-708-9. DOES makes over 700 H.P. on a very similar combo to yours with INDY's,
The guy drives to & from the track, albeit thermally stabilized, and easy driven, yearly lifter rebuild/replacement, and 300 run INDY rocker cycle out.
I just "cringe".
Bob
