After 14 mounths of collecting parts ,i am starting all over
Wanna buy a car, Pete ???
Hey Pete Walt , you seem to talk a good story but nothin goin on , what's happening.
Some on here seem to get things done , abuse the motors & keep em clean , all @ the same time. :D :D
:dontknow:
:thumbright: ;)
pete walton wrote:Just the engine i am having trouble with :? :? :?
You control the job , it don't control you. :read2:
There should never be a problem , just a set back. ;)
Typical management spin, I use it all the time ;)
No management in the heating game Pete , just what me old Dad taught me. ;)
Whats the prob Pete? (walton) motor no good for you???
Re: After 14 mounths of collecting parts ,i am starting all
pete walton wrote:Seems i just can,t help myself .Need some therapy, :lol: :lol:
Just my :mytwocents: as they say......
Looks to me that you need to decide what you really want & plan for that route only
If you keep changing your mind mid way through, distracted by the odd beautifull exotic piece, which is not in your plan, then you never gonna get there or you will but at a higher expense
Mick
Post by Mick »
What is your performance goal, 11's 10's 9's, you need to decide and build to suit. A car as light as yours, will go 10's with an half decent stock engine, good solid cam, eddy heads, 11 to 1 comp and a decent converter, 9's would take a little more comp, full port heads and a decent roller, or build a stroker and use max port ez's like Cliff and Pete.
Mick
Mick wrote: A car as light as yours, will go 10's with an half decent stock engine
Stop winding up the A bod boys.
Mick , you talkin straight 6?
:D
I take it you are sticking with track car only - which I think would be a wise choice. Easy.
Light car, lots of convertor - 5K plus (maybe a transbrake, they are cheap now), cheap stroker, lots of compression, C12, lots of timing (ignore what the books say), ignore the spray, big roller cam, big heads, single 4 bbl (I suggest a 1050 Dommie), spool, high gears, Big tyres (Oh, I see you already have that covered), job done.
Its the "hybrid" cars that want to be street and strip that struggle the most, and as a result cost the most money.
:D
Your motor costs more than Julie's car :P
