Woody wrote:Ray, thinners will remove tar spots etc and other little bits . It's o.k to use thinners in a small area but I wouldnt reckomend it to use on a large area like the glue behind the trim. The thinners will remove paint but in a small area you could get away with only a small amount of paint loss.
It's just not worth the risk with thinners when so many other useful ideas have come forward.
thinners is okish on modern 2pac paint , that has been painted for a long time , but you need to what your doing , as it can still make it soft .
if your not experianced with stuff like this ..use paint shop degreaser, (panel wipe) .... you can also get glue remover , from wurth but ..its not worth it ..escuse the pun as panel wipe does the same job & cheaper
