Got the stiff wall slicks , stiff sidewall is an understatement
, managed to get from 3 1/2" to 5" of front end travel , also reconfigured caltrac settings , fitted the 90/10s
, tossed the nitrous controller in the bin & carried out some modifications to the nitrous system , did some surgery on the dommie , loads more but i can't remember , will see how it all pans out.
It's interesting to see what actually happens when the nitrous solinoid is pulsed via the controller.......... NOT MUCH
, seems when the Bananarama! a dead stop it very quickly turns to vapour/gas , the controller pulses the noid pretty rapidly (on/off) , had the carb off so was watching the nitrous flowing through the plate , with the solinoid open continuous the flow is as would be expected , when the solinoid is pulsed the nitrous flow drops off around 80%
due to the nitrous for some reason turning to a gaseous state , as said all i can put it down to is the continuous dead heading due to the solinoid pulsing rapidly , maybe the nitrous gets 'bounced' back & forth so quickly causing it heat up.
No more pulsing noids for me.
Looked like Mr frosty after 10lb of nitrous flying around the garage.
