Couple of mods to me Chally
Les Szabo
Post by Les Szabo »
DaveB wrote:Remember seeing a pic of Pete Austins 71 cuda at mid track with a nitrous burp,the flames came out forward,I reckon,as Dave says,they wont work at speed.
Looks cool though :thumbright:
And I thought he ran 10's on motor.. :o
Adrian Worman
Post by Adrian Worman »
I managed to find a way to fit the base without the spacer, just need to find a 90 deg fuel fitting for the carb that's all, even clears the coil where it is.
I fired it up last night to make sure the intake was air tight and it ran very nice, warmed it up and checked the AFRs on the meter and they had leaned out a little bit. Very snappy response off the throttle tho :thumbright:
Jesus built my hot rod
72 Challenger
65 Barracuda
Regarding the 90 degree fitting - is it AN -6AN you require?
Jon Connolly
Post by Jon Connolly »
I`m no expert but I think Dave is right about the air and it has certainly worked for me .. I know you can`t do it with your hood but I have done these things with my pick up truck.
1 - Stop " hot bridging " between engine block and carb with a plastic or phenolic spacer.
2 - Get the filter right out of the engine bay as high as possible and use a filter top.
3 - Seal the underside of the filter so only " outdoor air " can enter.
4 - Get a scoop with a high level intake and smooth passage over and behind filter so pressurised cold air is available at all sides and top of filter
Slippery slope Ad .. spare hood with scoop / spare filter etc etc ;)
Adrian Worman
Pete wrote:Regarding the 90 degree fitting - is it AN -6AN you require?
Yeah I think so Pete, just for the fuel inlet fitting to the float bowl on an AFB.
I been thinking about buying stock from one of the manufacturers of pipe fittings and retailing them thru work..... any thoughts?
72 Challenger
65 Barracuda
Let me know if you need one...I may have a spare knocking about..
I've got a load of new Earls/Aeroquip fittings Ade, I'll bring a box full in and you can help yourself! :thumbright:
great idea ade, :D
Adrian Worman
Earl's Hose ate only at Silverstone, I spoke to a guy there a couple of months back, a lot of the fuel fittings are the same as we use for commercial oil and kerosene heating systems.
I was shocked at the price of the stuff on websites, sure I can do better and shift some stock ;)
Thanks Pete for the offer, same for you Unkie :thumbright:
That cold air box of Jons looks really well thought out, keeps the hot air away from the filter and carb nicely.
I remember seeing ram air systems on 442's, Firebirds and GTO's, not to mention the famous ones on Mach 1's, but they're all based on flat hoods.
72 Challenger
65 Barracuda
Mick70RR
Post by Mick70RR »
Adrian Worman
Mick70RR wrote:This is what you need Ade.
http://www.ebay.co.uk/itm/EDELBROCK-808 ... 51a2f41a0d
thanks Mick that's just the jobbie!
Me mates at USAutos got it in stock, sweet :thumbright:
72 Challenger
65 Barracuda
Ade, backing up Pete and Dave's points on whether air can be of a ram effect so low to the bonnet, I read a lengthy article on this the other night that suggests not. The article was on whether there is any point in activating the dummy air scoops on a '73 Roadrunner bulge hood. No point by all accounts.
roadrunner hood.jpg (4.16 KiB) Viewed 1271 times
AllKiller
Post by AllKiller »
Drew ...my car didnt go any faster with the scoops open, that i noticed...but there was always hope...
but as has been said they are too low to drag in the cold outside air at speed
I did notice that under hood temps were down a bit though...that helps
hence the new AAR type hood being made :twisted:
ALL KILLER NO FILLER
AllKiller
Post by AllKiller »
opps double post ?
Mick
Post by Mick »
Did you seal the carb to the bonnet though Steve ?
Mick
