Thompson performance
rockinpete
Post by rockinpete »
Garp wrote:
rockinpete wrote:After watching the video I decided to just go ahead and buy one, it arrived yesterday and took ten minuets to fit. The plate does exactly what it shows in the video and make the engine run very smoothly in the garage.
Yet to try it on the road :thumbright:
Pete,
It took you only 10 mins to fit - did you fully remove your carb' and do it on a workbench, or just do it in-situ'?
Still need to fit mine.....
No mate left the carb on, put a small bit of cloth down each barrel as blue said in case I dropped the washer/gasket and just took it off swapped the washer for the plate and put it on. Just need to make sure when you tighten it up that the squirters are central to the carb and they line up equally with the holes in the plate.
I only needed to have two goes before it all lined up and make sure you don't operate the carb with the squirters off.
To be honest the only fiddly bit is the lining up part the rest is simples !
Garp
Post by Garp »
Blue wrote:You'll be able to do it in situ but it will be fiddly if you still have a choke plate. I would recommend stuffing paper towel down the carb bores for when you drop the bits half a dozen times :lol:
Cheers Blue - just worried I remove the carb', stuff the gasket and I'm all at sea till a new one arrives ....
:P
:P
Yes I removed the carb,I am a clumsy ass,but stuffing a rag down there would be fine :)
Interesting, I've just ordered one for mine. Expensive for a bent bit of metal, but worth it if it works....
rockinpete
Dom66 wrote:Interesting, I've just ordered one for mine. Expensive for a bent bit of metal, but worth it if it works....
I thought that as well but when you look at the video it has got to make the engine run better even if you had no stumble problem to start with. Wait till you get it, a large box with a tiny jiffy bag in the corner :lol:
Just been advised of sending, how long did yours take to arrive ?
rockinpete
Only took a few days, but then you have to go to the royal mail parcels office and give them another £16 to get it !
rockinpete wrote:
Dom66 wrote:
rockinpete wrote: I thought that as well but when you look at the video it has got to make the engine run better even if you had no stumble problem to start with. Wait till you get it, a large box with a tiny jiffy bag in the corner :lol:
ffs :roll:
rockinpete
Dom66 wrote:
rockinpete wrote:
Dom66 wrote: Just been advised of sending, how long did yours take to arrive ?
ffs :roll:
Did you get it OK ?
RW71
Post by RW71 »
Any results to report yet guys? :)
rockinpete
RW71 wrote:Any results to report yet guys? :)
I had no problem so I can't say it has cured anything, but it certainly ran and picked up smoother after fitting even with the timing way out ( 2* at idle and 22* total :roll: ) Now at 13* at idle and 33* total and runs even better, just got to change the springs to bring the total in quicker. :thumbright:
Mine's arrived, but god knows when I'll get a moment to fit it. In the middle of building an extension at the moment, on top of the day job....
I'll report when I do though.
