Blue wrote: Fri Feb 16, 18 11:32 am
Interesting, I have what I believe is the only other 2 door '68 Valiant in the country, mine is an original 4 speed car.
so sort of off track a bit but as i said i'm leaving the slant six in the valiant for this summer as i need a car to use for a change.
so..... i may use one of the to4e turbos and cobble together a draw thru turbo setup for the slant six to 'pep' it up a bit
i've got a 465 holley which'll be in the ballpark size wise for a 3.7 engine so it's doable. i'll let you know how it goes
i've done 2 things to the valiant this weekend i fitted the new drivers door lock so after sitting on my drive since i bought it i can finally lock it up. secondly i put about 6 gallons of petrol in it as my son in laws focus died with a nearly full tank.
yesterday i agreed to buy a 950 double pumper from a mate, he's using it until the summer's over (not long in the uk) then fitting a pair of new edelbrock e-force 'blower' carbs to his 6/71 blown 400 sbc.
now i know a 750 d/p would be preferable for my 383 sbc but beggars can't be choosers and it's definately the right price. it'll need converting for blow thru but that seems simple enough, so after a rolling road session to get it jetted right it'll do for me. neil.
carb update, while looking for something in my shed i found an 850 double pumper i forgot i had. it's already had the choke horn machined off so one less job to do. i'll carry out the rest of the 'blow thru' mods in between jobs this summer. i'll probably still buy the 950 as it's cheap, then i can forget i have that one too, lol. also it looks like most of the interior will be replaced. i've found a set of black leather ford scorpio seats very cheap. i've used them before a few times and they are supremely comfortable.
neil.
i bought a th400 trans today to go behind the turbo motor. another step closer.
oh and i picked up the steel rings i had made to centralise the pcd adapters so i can temporarily fit some nicer wheels while it's still stock.
neil.
i had a little time today so i offered up one of the pcd adapters on the back with one of the 7 1/2 x 15 weld rodlites to check clearance. it looks like i won't get much more than a 225 or 235 tyre under the arch. unless i get my arch rolling tool out and 'make' more room that is. i'll get a secondhand tyre fitted so i can have a better look.
oh, and 2 of the cackhanded nuts stripped their threads when putting the wheel back on so i banged a stud out to match them up with r/h thread studs at work on monday.
neil.
i took an adapter, a wheel and a cak handed stud to work today. got 10 r/h thread studs and nuts, we didn't have the right size sleeve/lug nut for the wheels so they'll be ordered and i got a bald 205/60/15 tyre fitted (for free) so i can verify arch clearance before buying a new pair of whatever size. on the down side i cut a big flap of skin off the end of my left index finger at work with a stanley knife first thing this morning. the local a&e have stuck it down with 2 packs of steri strips but it's going to be a right pain for probably 2 weeks ish which is annoying and it throbs like a mutha
hi dave, yes pics are coming when there's summat to show. meanwhile more parts buying, i don't want to skimp on either the fuel or ignition systems so today i bought an earomotive A1000 carburetted bypass fuel pressure regulator, part number 13204. i got it now as at £100 new and still in it's packaging it is a bargain. i will of course be using an a1000 pump to match, we'll see if i can snag a bargain on one of those too. the parts pile is getting larger and just like the regulator does with boost my smile gets bigger on a 1:1 ratio with each increase. i actually got the valiant in my garage today between jobs so i can swap the studs and get the wheels mounted so there'll definately be some pics then.
neil.
