Post
by Anonymous » Sat Aug 04, 07 7:30 pm
Gonna go for the Cheater system , controlled by a Jacobs progressive controller, will cut the nitrous if the fuel pump/solinoid fails , or if i stupidly drain the fuel cell.
New to this , so if anyone has a better/safer way of using Nos , pleeeeease let me know.
Posts: 13955 Joined: Sun Apr 18, 04 11:04 pm
Post
by Kev » Sat Aug 04, 07 7:31 pm
Speak tomorrow, fella!
The name is Kev, nowadays known as Kevvy or Pommie C***! </center>
Post
by Anonymous » Sat Aug 04, 07 7:34 pm
Look forward to it.
Rogue Trooper
Posts: 1792 Joined: Wed Feb 01, 06 8:19 pm
Post
by Rogue Trooper » Sat Aug 04, 07 8:34 pm
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
AllKiller
Posts: 15191 Joined: Fri Jun 04, 04 9:33 pm
Post
by AllKiller » Sat Aug 04, 07 9:11 pm
it gets complicated
ALL KILLER NO FILLER
Guy
Posts: 5002 Joined: Sun Apr 18, 04 10:20 pm
Post
by Guy » Sat Aug 04, 07 10:15 pm
yes very complicated.
Click on picture to see all the wires
This is the wiring I did for mine it always worked when in the pits but would never fire on the track
. Then decided to go another route plus I was total skint and wanted to go to the Nats.
Post
by Anonymous » Sat Aug 04, 07 10:21 pm
Guy , where did you get the plate from that sat the solinoids on , nice neat bit of kit.
That wiring diagram does'nt phase me in the least.
AllKiller
Post
by AllKiller » Sat Aug 04, 07 10:24 pm
get some Ali and yer tin snips out Adam
Post
by Anonymous » Sat Aug 04, 07 10:25 pm
pete walton wrote: I am having enough trouble with one carb let alone nitrous
I just do not think i have the brain capacity for all this
Nor me Pete , feel like a stock broker , all burnt out.
Guy
Post
by Guy » Sat Aug 04, 07 10:27 pm
I made it. 1.5mm ali plate. The wiring didnt faze me either when I removed the nitrous controller I adapted it to use it as a launch control which if the NOS had worked would have released the brakes as the NOS was activated. The brake part of it worked fine
A poor mans transbrake
AllKiller
Post
by AllKiller » Sat Aug 04, 07 10:30 pm
is that trans brake ??
AllKiller
Post
by AllKiller » Sat Aug 04, 07 10:34 pm
With nitrous.....
