MCK's Challenger engine is ready...
MCK, if B body steering linkages work on an E body, I have a drop link bar that may clear your sump.
Your welcome to try it anyway :thumbright:
so we might see you at the sun inn next month then lol
Philth
Post by Philth »
MCK,
Ref. your Challenger's steering...
My Challenger has a 'drop' link steering bar, with room to the pan (big block). You may also want to check which way round it's fitted - believe it or not it can be put on the wrong way round (shocking lock to lock!).
I'll try and put up some piccies I took tonight...
1973 Dodge Challenger
MMA 616
Philth
Post by Philth »
Er, when I said "what way round it's fitted" I meant left to right, not upside down - the tapered holes wouldn't allow that!
Also, the factory pan has a form in the pressing on the right hand side to allow for full right steering lock clearance...
MMA 616
MetalChuckKey
Post by MetalChuckKey »
Thanks Philth and Phill ( :D ) I didn't know Challengers had a drop link available. There's certainly no aftermarket ones that I've seen. I've now had some steel shims made by a mate with a CNC machine at his work. As per Duncan's advice the motor has been raised a half inch by bedding these shims under the mount plates, and now the straight link clears the steering! Just. For the price of a crate of beer :thumbright:
Also, the guy that built the motor is travelling down to prime and start it to ensure nothing untoward happens. Should be next Saturday with any luck.
The rear leaf springs are to be mounted now on the custom rear eyelets shown in the pic. The turrets are to be ground off, this will lower the car by a few inches. Still won't be stock height though, I'll leave it to settle for a few weeks as in another thread before deciding what to do.
My aim is to have the most un-numbers matching Challenger in the club! :twisted:
challenger
Unmatching nos ive got seriously unmatching nos car and i hate to think how many Duncan has got :D
Rogue Trooper
Post by Rogue Trooper »
My aim is to have the most un-numbers matching Challenger in the club! :twisted:[/quote]
:lol: not long to go then, you must be close by now :read2:
1934 Coupe
1954 F100
1972 Norton Commando Fastback
Your Mum Says Hi.
Mopar a God amongst insects.
Yes. The V8 Challengers have a slight drop in the link. Never looked at a 6 cyl version.
The B-body one will probably be the same if you want to take Phill440 up on his offer.
All I know is that a 1970 Challenger has a 1 year only unique Pitman arm, what's that all about???
MetalChuckKey
Pete wrote:All I know is that a 1970 Challenger has a 1 year only unique Pitman arm, what's that all about???
:) Is there anything on a 1970 Challenger that does fit later cars??
MetalChuckKey
Went up there again today - can't wait to have it out of there so I can work on it myself. Pictures of the whole car as it looks are impossible due to the general clutter in the workshop.
But I did get these few taken showing what's happening. Apparently the engine's going to be running by the bank holiday weekend. A bold claim!
MetalChuckKey
These show the stance is still wrong, and the reason why.
Rogue Trooper
Not long MCK, keep your chin up, pipes look good :thumbright:
1934 Coupe
1954 F100
Your Mum Says Hi.
I hope the spring perches are getting welded better than this! :shock:
MetalChuckKey
Dave wrote:I hope the spring perches are getting welded better than this! :shock:
Don't count on it.
