Posts: 22108 Joined: Sun Apr 18, 04 10:49 pm
Post
by Pete » Wed Apr 08, 15 6:15 pm
Have you pre-oiled the engine?
Are you breaking a new hydraulic / flat tappet cam in?
Dart Vader
Posts: 3532 Joined: Mon Sep 03, 07 5:27 pm
Post
by Dart Vader » Wed Apr 08, 15 6:29 pm
Will pre oil using an old dizzy
What do you suggest for the hydro lifters?
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Post
by Pete » Wed Apr 08, 15 6:37 pm
You need to coat the lifters and cam lobes to death with Comp Cams break in Lube....Car gets very hot on break in so keep an eye on the temp gauge..........
Dart Vader
Post
by Dart Vader » Wed Apr 08, 15 7:04 pm
Yep, loads of break in stuff on them, also have the oil additive
Will download that pdf
Thanks for that
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Posts: 7309 Joined: Fri Nov 04, 05 8:40 pm
Post
by MilesnMiles » Wed Apr 08, 15 7:13 pm
It's worth a read mate, very specific advice on how to get the motor to fire first time. Hope it all runs up well, I'm sure it will
Posts: 8368 Joined: Sun Apr 18, 04 10:50 pm
Post
by db » Wed Apr 08, 15 10:56 pm
Exciting times
Good luck!
Dart Vader
Post
by Dart Vader » Sun Apr 12, 15 10:52 pm
I now have a cylinder head in the back of my daily......
Needless to say the car didn't fire up!
The two end exhaust manifold threads are leaking more than the US state department.
Gonna get them resleeved and studs put in.
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Post
by Pete » Sun Apr 12, 15 11:06 pm
You have to silicon the studs in all cases as the stud holes / threads all break into the water jackets....
Dart Vader
Post
by Dart Vader » Mon Apr 13, 15 10:24 am
Yep, the threads have rusted out. Tried to helicoil them but no joy.
Grrr
Getting frustrated with it all now!
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Post
by Pete » Mon Apr 13, 15 10:28 am
Major bummer...
Are you going to have to turn up some over-sized stepped studs?
Dart Vader
Post
by Dart Vader » Mon Apr 13, 15 10:55 am
Going to take the head to John osullivan, he runs Mr Mopar drag car and has an engineering place in swindon
1970 Dodge Dart
1995 Mustang GT
1980 MGBGT
Post
by Pete » Mon Apr 13, 15 10:58 am
Fair play - if you are running headers you need to keep the studs / nuts small or you will not have the space to fit them.....many are 3/8" or 7/16" Spanner size for this reason...........good luck, hope it sorts out OK...
Posts: 12076 Joined: Tue Feb 01, 05 10:37 pm
Post
by latil » Mon Apr 13, 15 10:59 am
On my old Fury I had this. managed insitu to drill out hole to next tapping size and re thread next size up and open up holes in manifold to suit. And yes silicon the threads.
V8 Sam
Post
by V8 Sam » Thu Apr 16, 15 12:16 pm
patiences my man..
patiences..
