Any ideas how I can mould a couple of Slicks?
Thanks Guy- missed that by minutes! Adrian texted me but i was stuck with the boss til it was too late- another thing to hate him for
Imagine the scenario , bottle in the boot with a -6 nitrous line (20ft length) , the motor will be flooded with fuel BEFORE the nitrous makes it's way to the plate , not only will the cylinders be fuel rich the motor will bog off the line , this will also be the case when 'banging through the motor' without any way to purge the nitrous line , the advice given in this thread is only the tip of the ice burg , you've gotta break parts & spend sh$$t loads of money to understand the BASIC principles of nitrous run motors.db wrote:The purge just seems such a waste and it's dealing with the problem after it's happened.
Liquid nitrous will revert to vapour in a short space of time................leaving nitrous lines pressurised for any length of time will damage solinoid plungers & restrict flow , not good........... how do you propose releasing the pressure after a run? , ok you can remove line from bottle but that stuff gets pretty cold when sprayed over the hands/arms/face.db wrote: Won't that 20' length contain liquid nitrous from the start, held in by the solenoid or does it escape over time?
It is a bit frustrating when trying to pass on your experience about a subject as diverse as this then to be accused of cudgoulding (how do you spell that?).Dave999 wrote:well yellow bullet seems to be filled with smug Bananarama! who
Although certain posts in this thread have now been deleted i don't believe anyone was trying to prove anyone else wrong
can't be wrong if it does what ya want.... and is legal
and it only does what you want if you try some stuff out, take a bit of advice, ignore a load more, and take the odd risk.
I feel that enthusiasm to do something different, to post something different,to veer off the beaten track, is being cudgeled into the ground
so much better to try and be supported in ya quest and then maybe have to say OK it doesn't work or hey it would have been easier if.
than not try at all.
