Present set-up is:
BG750 dp carb, M1 inlet, BG220hr pump
360ci, Barton indy heads, 10.2:1, ultradyne .580" cam, 450-ish hp.
ProTrans built 727, rev patt manual body, PTC convertor.
Ford 9" Detroit locker 4.57:1, Strange S/S 35 spline, 18.5"x 29" MT's
I've been trying to do my own research but now have more questions than answers!
Q 1. If i put say 250hp nitrous through that lot, what will break first?
Q 2. 'You shouldn't use a plate on a single plane type manifold, you must use separate injectors for each cyl' is that true?
Q 3. 'For every 50hp added, raise spark plug heat by one step'. Is this A- true, B- essential/ recommended/ only for racing...?
Q 4. What are the 'essential' add-ons- i.e. stuff you don't get in a kit but the experienced sniffer wouldn't be without, eg gauges, purge, bottle cooler, progressive controller, etc.
Q5. What size bottle for occasional street, once a year strip use?
Q6. How much to fill say, a 10lb bottle?
Q7. What's likely to go wrong with a used kit?
Q8. Do you need a separate fuel line/ pump/ regulator or can you tee off your main fuel line (assuming it flows enough for both demands)
Q9. Would taller gears be a good move?
Q10. Anyone selling a nitrous kit?
Thanks folks
