Fuel pressure regulator
I figured this was a good place for this I DID find something
Drew that sounds like your problem could be the ignition switch (they die after 40 years) or a bad connection in the connector on the column
It is the switch , and it is only 5 years old :oops:
The pot metal body has gotten loose with the plastic wiring harness and when I would turn the key it would flex and separate,and loose connection/contact
and the spring inside is knackered so a new one is on order I hope it lasts longer than 5 friggin years for crying out loud :x
DSC00092starter switch.jpg (123.47 KiB) Viewed 151 times
I am right sometimes then. :D
Dave wrote:I am right sometimes then. :D
Yes indeed the fact is I posted this and it made me think and not assume the switch was bad
I thought it might have been the MSD box or something else but since the switch was only 5 years old how could it be bad? ...............well it was bad ,so good on you Dave
at least you can get new
mine is held together with screws from cheap sun glasses and features a cable tie and some bits of paperclip...
dave
Dave999 wrote:at least you can get new
dave
Yes I almost did that , and in fact since the units like to fail I want to do some thing to give the new one more life :?
