Will´s 1968 Dodge Truck
Re: Will´s 1968 Dodge Truck
Once I had machine the long slot I installed a thin semi translucent (milky) strip of polycarbonate...
This panel will be screwed to the ceiling upside down and control all functions of the truck
Next I installed a fine selection of IKEA 83p budget kitchen cabinet door handles
LED technology is getting better every day but 24v is still where the price point is for commercial grade chip sets
I mounted chip strings onto aluminium and then placed this behind the polycarbonate strips for a beam of light affect
The system is using a 12v to 24v step up invertor but as LED pull very little current this is tiny.
Went a little over kill on the LED front with 120 x per meter = 600x 2835 LED chips producing 2735 Lumens :shock:
My interior now looks like 2 x lightsabers left hanging by a Jedi so I installed a dimmer system which works really well from 0-2735 Lumens
Got to be different !
Welding slowly getting there. Spending to much time trying to get body pannels lined up.
kma176
Post by kma176 »
That a tight fit on the firewall ????
kma176 wrote: Fri Jan 18, 19 8:33 am That a tight fit on the firewall ????
My thoughts too!
Any chance that engine will vibrate a little??
mygasser
Post by mygasser »
Pete wrote: Fri Jan 18, 19 9:51 am
My thoughts too!
a mate had a cummins and manual box from a leyland roadrunner 7.5 tonner in his f150 and it was surprisingly smooth. monster torque!
Painted front pannel to check colour today
Good old fashioned Ford Capri diamond white !
Love it !
Yep going to recess a section on the bulkhead once front panel is bolted in place / wings / then bring Cab forward.
67 Liters of white topcoat :shock:
Willy...……………………..you`re "NUTS" =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> :plymouth:
Big thanks to Mr R.Runner for the call today explaining that my intercooler set up on front looks silly a I should count a few rivets and keep the original face.
Welded back together the front grill I had cut up :cry: :plymouth:
#-o #-o #-o
"GOLD" would look better =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D> =D>
The "Aston" looks sweet =D> =D> =D>
