Will´s 1968 Dodge Charger
I'd run a loop in each fuel line, that should sort out any flexing issues!
GTXJim
Post by GTXJim »
I ran 1/2" alloy hard lines from pump to that part of the chassis, then ran flexi under the chassis, then back into hard lines up to fuel regulator mounted on the firewall then flexi to the carb :thumbright: :thumbright: :thumbright:
Hell Yeah!! I'm a Redneck
I used 5/8 stainless steel Tube and made hard lines for the engine bay.
<a href="http://s73.photobucket.com/user/autofet ... d.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... r60xid.jpg" border="0" alt=" photo D305D5DB-76BD-4DDE-ACA7-6ADA3561E2B0_zpspmr60xid.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... p.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... weyf5p.jpg" border="0" alt=" photo 0CD657C4-AED2-4D9D-A0BB-8F09A6A4A706_zpsyrweyf5p.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... f.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 3fwajf.jpg" border="0" alt=" photo 7AB1F274-0131-4ED6-8556-D996BEDBE09E_zpsju3fwajf.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... w.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... lbovdw.jpg" border="0" alt=" photo 3EE7BEA8-41FD-4B1E-8EA6-AE1EBC63E444_zps1jlbovdw.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... t.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... fumsxt.jpg" border="0" alt=" photo 12BB93DF-81A9-4104-A7A7-C83B447A2107_zps6vfumsxt.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... f.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... xc6u8f.jpg" border="0" alt=" photo 9A1AF437-2C57-4A2C-86D2-893F5571ADE1_zpsthxc6u8f.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... e.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ep4ude.jpg" border="0" alt=" photo 0F1F4FE2-94A6-470E-84BD-DE97E211A028_zps7aep4ude.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... j.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 6vxuij.jpg" border="0" alt=" photo 44423AD8-5842-42F6-BF39-3B82D9F62813_zpsb16vxuij.jpg"></a>
That looks like a lot of work! Very smart though 8-)
A lot of work you have done there Will :thumbright:
Will you be having a filter before the rail ? if not, you may want to consider, as injectors don't like particles of dirt.
There is a 100 micron in tank then will put a 10 micron under fender
autofetish wrote:There is a 100 micron in tank then will put a 10 micron under fender
I knew you would have it covered ;)
Need every bit of advice i can get !!!!!
thank you :thumbright:
Next up I made a silly mistake. I tried to silver solder some AN-10 fittings onto my heater matrix’s.
I did this with a blow torch this took so long to get the fitting up to temperature it melted most of the solder in my heater matrix.
So I took it to my very good friend David and he fixed it. The trick was oxy acetylene would get a very localized area very hot fast so not affecting other parts of the matrix’s.
Initially low pressure testing and finally high pressure testing with Nitrogen at 2.5Bar -36Psi
A very funny night
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ntadvs.jpg" border="0" alt=" photo 16D1D780-6CF8-4969-8E34-65DA73BBECA5_zpsv5ntadvs.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... sb5mkm.jpg" border="0" alt=" photo 00282397-FB84-4C11-BAF6-2BC71E472A4E_zpszasb5mkm.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... nhffxa.jpg" border="0" alt=" photo DD6E4428-5744-4532-A434-21633B08198F_zpsppnhffxa.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... xmpif0.jpg" border="0" alt=" photo FB85142B-20E5-4727-A9ED-170EA69D0650_zpsvyxmpif0.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... ergwbx.jpg" border="0" alt=" photo 39DDF881-7FB0-43D4-830F-6460C21F6C83_zpsbxergwbx.jpg"></a>
<a href="http://photobucket.com/" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... q6iz3g.jpg" border="0" alt=" photo A521C343-9338-4714-A68B-DEC1EA42F042_zpsliq6iz3g.jpg"></a>
What's a Heater Matrix??? :scratch:
Good work as ever! :thumbright:
Jon Connolly
Post by Jon Connolly »
Yep ... can`t beat a bit of " crossover refrigeration engineering "
Just watch for copper work hardening and splitting ????
Carl
Post by Carl »
Pete wrote:What's a Heater Matrix??? :scratch:
A film I think?
*MMA-609*
"Built to be driven!"
Why me??? :banghead:
wils quiet... Is he on tour or blown himself up against the garage wall...?
Bryan
Post by Bryan »
nice to see a fridge guy stepping in to the rescue.
Been on tour
Hope all had a lovely xmass
Today I fitted my thottel air hat
It's originally designed for Machanial fuel injections but I have had electronic fuel injectors fitted.
<a href="http://s73.photobucket.com/user/autofet ... u.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... olh96u.jpg" border="0" alt=" photo 5DAEACFC-E2BC-4312-9CC8-99B34B224471_zps04olh96u.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... k.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... rvcpak.jpg" border="0" alt=" photo DA342BE7-6F36-49EA-951B-F9ED21E9F908_zpsbxrvcpak.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... b.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... uitzeb.jpg" border="0" alt=" photo D5CEAC2E-F5E5-4B1F-9C66-11A0AB29D4C6_zpsxpuitzeb.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... q.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... bnbr6q.jpg" border="0" alt=" photo 9998D97F-8135-4EAC-BFC4-20FC0C4AFCDE_zps14bnbr6q.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... 0.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... brr6n0.jpg" border="0" alt=" photo 2E376527-23BB-47CF-B608-F0835FE01296_zpsd0brr6n0.jpg"></a>
<a href="http://s73.photobucket.com/user/autofet ... x.jpg.html" target="_blank"><img src="http://i73.photobucket.com/albums/i205/ ... 4fa5gx.jpg" border="0" alt=" photo 18C2EFB2-5491-4758-BBA5-6E6E661519B5_zpszs4fa5gx.jpg"></a>
